Hi again
I’m finding that the dropdown lists are not be saved or retrieved properly.
Also date styles are not being saved as when I open files the date style is ? generic, even tho I saved the style ad dd/mm/yyyy.
Martyn
Hi again
Martyn
It seems I’m having problems with duplicating those issues. Could you please outline them in a few steps?
I assume you mean GS-Base 8.2 not the early 9.0 beta?
You are having trouble duplicating because I’ve made a mistake, I’m pleased to say. Please delete the report as it was puring user error on my part!
Regards
Martyn ![]()
