Problems with loading text files with Unicode headers and without field names: textual representations of numbers couldn’t be converted to numbers automatically in such files.
If a *.zip database table contained the UTF-8 header (which was added several days ago), the “Save” commands might cause removing the last 3 characters from the last field of the last record.
The “estimated time left” value in the “Open/Save Progress” dialog boxes might be incorrect for very large text files (+nnn MB).
If the loading/saving was canceled by the user, the (unnecessary) “file read error” message was displayed.
The field statistics/break-down values were displayed in the “Field Setup” dialog box using a fixed general or scientific format (whichever was shorter). Right now, the actual numeric style of the corresponding field is used.
When inserting memo field references in the letter form when printing serial letters/reports, the inserted data was shown as rtf codes if the “plain text in memo fields” option was not checked.
When changing the field type from “Number” to “Text” or from “Text” to “Number” the data conversion was not performed automatically (the file required reloading or copying/pasting that column).
