This version includes the following new features and bug fixes:
This is the first 64-bit release of GS-Base. Upgrading to 64-bit will now enable you to use the entire available memory. (Vs. 4GB max. for the previous 32-bit edition.)
For text files more character encoding options were added to improve data conversion between various system language versions.
Drop-down lists can optionally automatically import (unique) data directly from database fields (in “real time”).
If a given field has some drop-down list attached, the corresponding column header is displayed with a marker (the same way as in GS-Calc).
If a user specifies an incorrect option for the character encoding when opening/importing a text (or xBase) file, GS-Base didn’t display any warning if some invalid UTF-8 (non-ascii) sequences were found. This could lead to not finding fields with such sequences when filtering records or using the Find & Replace functions, displaying some PCRE library errors or - in some rare cases - to crashes when using the Find & Replace function. Currently GS-Base displays a respective warning and shows where the invalid code is (in the imported text file data).
Fixed bug concerning (left) field trailing spaces in loaded xBase files.
Fixed possible bug concerning some character encoding variants for memo xBase fields.
For extremely large files, GS-Base 12.x may “react” very slowly when editing fields. The ver. 13 should be several times faster.
In GS-Base 12.x the Find & Replace function could be very slow on some computers for large data sets (e.g. +0.5mln records). In GS-Base 13 this should be tens of times faster.
