New features in this version:
- In-field charts as field formats. With one click you can create any number of mini-charts displayed in fields.
All parameters and display options are set up automatically. By default, you apply this in-field format to a field(s) at the end of a data series placed in a continuous group of other numeric fields. Chart(s) can be also displayed at the beginning of such a series - a plain cell text alignment (Align Left, Align Right) determines this.
You can use line, column and area charts. The maximum number of charts is the same as the maximum number of records: 256 millions. The maximum size of each data series is equal to the maximum number of columns - 1. To change the color, set the font color for a given field. - Sample in-cell charts:
