GS-Base 22.2 has been released
New features in GS-Base 22.2
  • In the “Verify Files” window you can now specify a list of locations
    (disks, folders) to be scanned using one list. Simply add subsequent
    locations separated by the semicolon “;”
    If you use the “Select Folder” dialog box, it’ll insert the
    selection at the current cursor position.
    Multiple locations enable you, for example, to monitor files and
    effectively find similarities or duplicates across multiple disks.
    Online help:
    Verifying File (Path) Lists in Tables
  • Regular expressions have been added to the “Find()” formula and
    to the “Replace()” formula.
    find(pattern, subject, [start], [flags])
    The optional 4-argument find() version accepts regular expressions
    as ‘pattern’ and can perform both case-sensitive and caseless
    comparisons.
    The ‘flags’ parameter can be any combination (sum) of the following
    options:
    1 - ‘pattern’ is a regular expression,
    2 - use case-sensitive string comparison (regular expressions
    switches can override this),
    4 - the matching substring is returned or an empty string instead
    of its position,
    32, 64, 128 - find the 2nd, 3rd or 4th capturing group (the 1st is
    the default one).
    =find(“e*\d”, “abcdef abcee abcde5”, 1, 1) returns 18
    replace(pattern, subject, start, replace, [flags])
    The optional 5-argument replace() version accepts regular
    expressions as ‘pattern’ and ‘replace’ arguments and can perform
    both case-sensitive and caseless comparisons.
    It searches ‘subject’ for ‘pattern’ starting at the position ‘start’
    and replaces all found occurrences with ‘replace’.
    options:
    2 - use case-sensitive string comparison (regular expressions can
    overwrite this).
    The ‘replace’ argument can be:
    (1) absolute references (by number) to capturing subpatterns, eg.
    \1, \2…\999,
    (2) \l, \L, \u, \U literals to (binary) switch upper- and
    lower-case conversion,
    (3) \r, \n - ‘line feed’ and ‘new line’ literals (by default,
    pressing Ctrl+Enter when editing fields inserts the \r\n
    sequence).
    =replace(“(.)a+\d{1,3}”, “abc aa0102”, 1, “\1”, 1) returns ‘abc 2’
    =replace(“(ab)”, “abcdef ghijk abb123”, 1, “\u\1”, 1) returns “ABcdef ghijk ABb123”
  • Although regular expressions can already be used with the manual
    “Edit > Find / Replace” commands, supporting them in the above
    formulas greatly simplifies all cases where you need to find or
    convert something within the calculated fields.
    The “Field Setup” dialog box screen shot:
    https://citadel5.com/help/gsbase/field_setup.png
    For example, to find/extract the extension from file path in
    “field1” and place them in the “field2”, for the “field2” field in
    the “Field Setup” dialog enter the calculation formula as:
    =find("(\.[^.]+)$", field1, 1, 1 + 4)
    To find/extract a folder from a file path:
    =find("^(.*[\\\/])?(\.*.*?)(\.[^.]+?|)$", field1, 1, 1 + 4 + 32)
    To find/extract the file name without the extension and path:
    =find("^(.*[\\\/])?(\.*.*?)(\.[^.]+?|)$", field1, 1, 1 + 4 + 64)
    To remove duplicated words in field1:
    =replace("\b(\w+)(?:\W+\1\b)+", field1, 1, "\1", 1)
    To create abbreviations consisting of first letters of words:
    =replace("(\b\w)(\w*(\W+|\z))", field1, 1, "\1", 1)
    leaving full numbers:
    =replace("(\b\w(\d*))(\w*(\W+|\z))", field1, 1, "\1", 1)
    To mask IP addresses partially (e.g. 11.12.13.114 to 11.12.13.*):
    =replace("\b((\d{1,3}\.){3,3})\d{1,3}\b", field1, 1, "\1\*", 1)
    For other examples, please see the “Full text searches and
    replacing” help topic.
    As regular expressions are extremely popular, even if you’re not
    familiar with them, whenever you need to use any specific find()
    or replace() patters, you can simply enter your questions in Google,
    like “regular expression to find file extensions”
