New features in GS-Calc 20:
- Changes concerning the xlsx support. Formulas are read and saved without conversions. Output xlsx workbook files can exceed 4GB if the underlying zip format is left as zip64.
- The GS-Base *.gsb file is supported directly and the *.gsb files are loaded as data table collections and save in the simple GS-Base file format.
- The file formats list in the “Open File” dialog box has been reorganized in accordance with the above:
- The “Recently Used Files and Folders” window now includes dates in the “Recent Folders” section. They show when a given folder was accessed for the last time.
- Bug fixes.
