Hi :>
Just noticed this: if you hover over the technical support entry in the help menu, the text that appears in the status bar refers to “techinal” support.
It’s probably been like that for years.
Not in any way important!
– Tim
Hi :>
– Tim
Thanks for reporting this. As a matter of fact, it’s an old text string/prompt. Just in case
the remaining ones will be checked as well before the next update.
